I am getting the error "Error setting debug context for run configuration Active Debug Context".
Some reading and I came "target configuration", which is greyed out. So I can't check it or change it.
Can anyone help me with the above error. I am using USB Multilink universal to (attempt) to program a MC9SO8AW32.
I have never seen BKGD go low, will check clock now. Ok, found one problem, needed b+ on another trace. Processor running.
But now I have these two new errors: According to the forum, a-lot of people do. Followed the suggestions in those posts and those pins seem ok. BKGD, VDD, Gnd, and reset.
Much Thanks,
David
Hi David,
Please accept my apology for the time delayed to get back to you on this issue, I was heavily backlogged!
regarding this problem, if it still there, then, could you mind upload an screen-shot to here for further investigating?
Thank your for your kindness.
Problem resolved, erased, re-flashed.
Thank your for at least replying, I was under pressure to get the job done by xx time and I am new to CodeWarrior,
It was about to drive me nuts, seemed like the simplest things didn't work.
But we got it done, a day ahead of time. :smileyhappy:
Thanks again for your reply. Have a great day and weekend
David
