Hi all,
I am using TWR-K60D1000M and want to communicate using UART3 in interrupt mode. I am using MQX 4.0.But I am confused how to start communication.Can any one answer me????
Solved! Go to Solution.
Firstly, you need to enable uart3 interrupt in user_config.h. Then, create an ISR function for uart3 interrupt, next, install the isr with _int_install_isr.
Please check the following link
https://community.freescale.com/thread/317094
Hope it helps
Hope it helps
Hi Daniel,
Thnx for reply.I have tried and it runs successfully.......:smileyblush::smileylaugh:
My pleasure.
