PWM on FTM2
PWM on FTM2
pramodtm-b46240
     I'm using MC9S08PT60 controller to generate a PWM using FTM2, using processor expert.I could generate the same on FTM0 and FTM1 and also could vary the duty cycle. But i want it on FTM2 so that I can control the speed of a DC motor, owing to the advantage that FTM2 supports complementary channels.Can anybody help on this?
pramodtm-b46240
Thank u very much...
weapon
Senior Contributor I
We have a bldc motor demo in TWR-S08PT, whihc uses FTM2 to generate 6 pwm signal to control a bldc motors. you can take it as reference.
The demo is in attachment.  Hope it can be helpful.
pramodtm-b46240
