APN List is Empty in Android ICS imx6
sanjeevsharma
Hi All,
While Working on 3G Support in Android ICS In Mobile Network APN List is coming empty and I am not able to set the APN Field's and along with this system doesn't read from apns-conf.xml stored in /system/etc/apns-conf.xml.
Have anyone faced the similar problem ?
Sanju
Labels (2)
max_tsai
hi, You may check the class, "TelephonyProvider.java", which builds the Telephony.db inlcuding "etc/apns-conf.xml".
max_tsai
sanjeevsharma
Hi MaxTSAI,
Now this problem is solved and now i can add entries.I should have hit the back button to save the entries.
giorgiosoldavin
I have the same problem, and I'm looking to TelephonyProvider.java code but: what have you done for solving it?
Thank you.
Giorgio
