Regarding 1080p decoding in imx6 sabre AI
srilakshmikanag
At present I am working on sabre platform for autoinfotainment.
Can "i.MX6 Quad" supports DUAL instance 1080p h264 decoding?
Please let me know
Srilakshmi
4guin4g4
Yes, it can perform 2 full HDS @ 30fps  decode or encode.
FranciscoCarril
Contributor V
2 Full HD decode is possible   if     videos are @24 fps.  When VPU is used at 266mhz which is the common situation
This is due to VPU troughput characteristics.
If VPU is set at 352MHZ  it can handle @30fps, but this feature is still under test.
