i.MXRT1020EVK mechanical design files
858 次查看
alphafred
I have a hard time finding the mechanical design files for my i.MXRT1020EVK REV A3 board.
I checked the provided mechanical design files on the i.MXRT1020EVK webpage (MIMXRT1020_EVK Design files ) but the layout files are for board revision B1 which as apparently major differences in the design. I want to build a custom housing for my test bench hence I would need exact header placement information.
853 次查看
jeremyzhou
Please check the attachment, which is the design file of the i.MXRT1020EVK REV A3 board.
Hope it helps.
TIC
847 次查看
alphafred
Thanks a lot - that was exactly what I was looking for.
854 次查看
jeremyzhou
Hope it helps.
TIC
