i.MXRT1020EVK mechanical design files
alphafred
I have a hard time finding the mechanical design files for my i.MXRT1020EVK REV A3 board.
I checked the provided mechanical design files on the i.MXRT1020EVK webpage (MIMXRT1020_EVK Design files ) but the layout files are for board revision B1 which as apparently major differences in the design. I want to build a custom housing for my test bench hence I would need exact header placement information.
jeremyzhou
Please check the attachment, which is the design file of the i.MXRT1020EVK REV A3 board.
Hope it helps.
TIC
alphafred
Thanks a lot - that was exactly what I was looking for.
jeremyzhou
Hope it helps.
TIC
