Subject says it all...
I have a small compact design coming up that needs two cameras. Can the 1170 support two?
Solved! Go to Solution.
Hi @EdSutter ,
Please check this post:
https://community.nxp.com/t5/i-MX-Processors/Two-camera-input-on-i-MX-RT1170/m-p/1356235#M181597
Wish it helps you!
Kerry
Ok thanks for the pointer. Seems at best it would be a bit of a kludge to do a 2-camera design then...
Hi @EdSutter ,
Wish it helps you!
Kerry
