I'm designing a board with RT1170 and checking register setting about SDRAM.
I'm not sure what value I should set for SDRAMCR2[ITO].
Is the purpose of ITO only for power saving? What should I consider when I set ITO?
解決済! 解決策の投稿を見る。
Hi @Eugene3 ,
To the ITO, it is the SDRAM idle timeout, you can refer to this information:
make sure it is <tRAS max is OK.
Wish it helps you!
Kerry
Hi @Eugene3 ,
Wish it helps you!
Kerry
