i.MX RT1064 evk freertos task creation failed
2,298 次查看
allen_tseng
My project using freertos, lwip stack(socket, http server, mdns, dhcp), uart, usb(composite, host).
And I add canbus function to this project, when the http server connecting, console show "task creation failed", and no reaction anymore.
DTCM, ITCM, OCRAM are not fulled.
I think this is about freertos heap or stack problem.
But it is using heap_3.c, I can not observe freertos memory usage in run time.
How should I do to solve this porblem?
Allen
2,293 次查看
danielchen
Hi Allen:
Please try to increase the heap size from the 'Managed Linker Script' as below picture shows.  Maybe the default value is not enough.
2,294 次查看
danielchen
Hi Allen:
2,288 次查看
allen_tseng
Hi Daniel
Thanks for your reply
My project had already set heap 0x10000 and stack 0x5000 before.
And still occur this problem.
I set heap size to 0x20000, the problem is solved.
One more question.
How do check the heap and stack usage?
Allen
2,280 次查看
danielchen
Hi Allen:
Sorry , current IDE can not show the heap usage when you using heap_3 .  MCUXpresso  IDE can show the FreeRTOS heap usage if you  are using all other heaps except heap_3.
