May I know how to connect timer to the encoder for low speed/velocity measurement?
Thank you!
Cindy
解決済! 解決策の投稿を見る。
While we currently do not have an example for the RT1050for motor control, you can use as a base the example for the RT1060 in the SDK.
You will need to make sure to add the motor control library in your SDK.
