Hi everyone,
I'm trying to configure the parameters of the SEMC for my SDRAM bank with RT1176.
In the various parameters, in the EVB settings the value
"sdramconfig.tPrescalePeriod_Ns" it's "160 * (1000000000 / clockFrq)".
NOTE: EVB use 2x16bit SDRAM mod.W9825G6KH-5I with CLK=200MHz.
I use different SDRAM chips with 166MHz CLOCK but I don't know what data must be use to calculate this parameter; I have configured all the other parameters correctly but I don't understand this.
Does anyone know how to configure this parameter or can point me to an APPNOTE that describes it.
Thank you,
Fabio
Solved! Go to Solution.
Hello
I hope you are well.
Prescaler period is used as a clock cycle count unit for refresh and bus idle timer period. Please refer to this example:
Omar
Hello
Omar
Perfect, the answer is exhaustive!
Is there a SEMC controller AppNote that describes how to optimize the setup of the various parameters?
The RT117xx family data sheet does not contain these useful explanations....
Many Thanks,
Fabio
