RT1170 External POR
RT1170 External POR
1,183 次查看
Eugene3
How long should external reset IC assert POR_B on the power up sequence?
I plan to use internal DCDC in RT1170. So I think external reset IC should assert POR_B until DCDC_DIG(for VDD_SOC_IN) and VDD_LPSR_DIG stable.
But I couldn't find the time spec in the DCDC section.
985 次查看
Omar_Anguiano
Unfortunately, we don’t have this specific parameter. I apologize for the inconvenience this may cause you.
You could use as reference the PMIC sequence but you will also need the PSWITCH delay.
4 回复数
1,158 次查看
Omar_Anguiano
Hello
I hope you are well.
The POR_B input must be immediately asserted at power-up and remain asserted until the last power rail reaches its working voltage.
Omar
1,071 次查看
Eugene3
Hi @Omar_Anguiano
Thank you for your replying.
How long does it take for the internal DCDC output to reach working voltage?
986 次查看
Omar_Anguiano
979 次查看
Eugene3
Thank you I understand.
