Is the RTWDOG timer available on the ARM Cortex development boards such as the RT1020 or is the board limited to just using WDOG1 and WDOG2?
Solved! Go to Solution.
Thank you so much for your interest in our products and for using our community.
In the Table 3. i.MX RT1020 modules list of datasheet you can check that the RTWDOG as well as the WDOG1 and WDOG2 are available on the RT1020.
Hope it helps you.
Have a nice day!
Hope it helps you.
Have a nice day!
