I am using sdk power mode switch example core 0 only . sdk e.g work fine but same configuration I did in my code I get stuck in bus fault handler at switchflexspiroot() . did we need to configure any other things also when we used sdk e.g code in our project . I am using set point 15 please help me how I resolved this issue. Also I want to know about the important point of low power mode when we configure that if we forget about this we didn't expected output
Solved! Go to Solution.
I recommend you to check the following application note that describes power architecture design, clock architecture, and how the low-power modes can be used and configured. Also if your own code does not work and SDK code works I recommend you to compare register, clock configuration and code flow to see if you can narrow down what could be causing this issue.
https://www.nxp.com/docs/en/application-note/AN13148.pdf
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
Felipe
