I've been using this board for a month, but trying a new software it got bricked.
When I try to upload a working project this is the result:
I readed about MCU boot utility, but when I try access to the board the USB is not found, and shows this error:
Then I put the board in Serial downloader and I can upload the firmware, but this is not working.
With the Serial downloader and MCU boot utility I have this message:
I need to unlock this to continue working. Does anyone knows what is happening?
Thank you in advance.
Hello @daniJVV ,
Could you please change the MCU Device in MCU Boot Utility to i.MXRT117x and try again?
[MCU Boot Utility's Target Setup]
Let us know if you have another issue.
Best regards, Raul.
Hi @RaRo
I tried to debug a touch screen example that was working before this problem, and now there is no errors when uploading the firmware.
But the problem with USB-HID MCU Boot Utility continues.
Daniel Prieto
Hello @RaRo
I got this message when I tried to connect with USB:
With UART I can connect, but I don't know which parameters to look at.
Is there something to check in any memory (boot image, eFuse...)?
Thank you for your help.
Hello @daniJVV,
Could you please try with the following steps?
[Testing configuration in a MIMXRT1170-EVK board]
Best regards, Raul.
