Does anyone have the ASCII format PCB files for the MIMXRT1020-EVK please?
I can't import the .brd file into Altium and I don't have access to Allegro.
It would be nice if the ASCII format file was always put in with the EVK Layout files.
Solved! Go to Solution.
The attached file is not in the email, you need to login to our NXP technical support portal in order to download it, the link is in the email.
Thanks for the help, I'll know for next time now
Hi @GAP8,
Already send you the private message.
Hi, thanks for the help but there is no attachment on the message you sent, I think my email security removed it. I have added you as an approve email address now, please could you resend the file.
