I tried the following procedure to build the MCU Bootloader for imxrt1160 EVK for CM7 core.
Kindly provide suggest how to overcome this issue/ any reference doc / steps available to find the solution for this issue?
cc: @kanimozhi_t
Solved! Go to Solution.
I was wondering if you can share the steps of testing, then I'd like to replicate the build error.
TIC
TIC
After updating partition file, can able to solve the issue
