I have a MIMXRT1050-EVK board with processor MIMXRT1052DVL6A I downloaded SDK for it but the SDK doesn't support config tools. However, SDK of MIMXRT1050-EVKB with processor MIMXRT1052DVL6B does support config tools. So Will it work if I use config tools for "B" version and use the generated pin_mux files in my projects for "A" version? Also I have seen some official page mentioning a silicon update between versions is this the only change between these processors/boards if not is there any file/page for list of changes between these versions? Lastly I could use general compatibility between these processors/boards. Thanks in advance.
Solved! Go to Solution.
You may refer to the document as the links.
Chip Errata for the i.MX RT1050
https://www.nxp.com/docs/en/errata/IMXRT1050CE.pdf ,.
i.MXRT1050 Migration Guide Migrating from silicon Rev A0 to Rev A1
https://www.nxp.com/docs/en/nxp/application-notes/AN12146.pdf
