Dear Friends,
I'm development a project with the MIMXRT1051 cross processor and I have a doubt: Can I use a RAM Memory (p.e. SDRAM) with nominal tension of 1.8V? The EVK (RT1050) use a RAM with nominal tension of 3.3V, but I need use a RAM with nominal tension of 1.8V.
Thanks a lot!
Rubens Júnior
Solved! Go to Solution.
Yes. Please find the NVCC_EMC voltage range as the below:
