We are trying to work with encrypted image over NAND flash memory. Flex SPI interface will be used for integrating NAND flash. We cannot use XIP over NAND flash and we need to run application over DDRam.
We need application notes for running OTFAD with NAND flash memory on Non -XIP approach. As per our understanding, this module can work with any flash memory through Flex SPI interface.
Please share any documentation supporting such implementation. Kindly share your views on same.
regards
Krutarth Raut
No. we are using customized board but we have EVK
