IMXRT1064 FCB address offset in ref manual rev1 vs rev2
541 次查看
djarin
The IMXRT1064 reference manual in Rev1 saying the FlexSPI Nor config parameters is located at offset 0x400. While in Rev2, there mentioned it is starting at offset 0x0.
Would like to know, since RM rev1 is published on year 2019, and if we have imxrt1064 mcu chip bought before year 2019, do we need to follow the offset address as 0x400?
also, we notice also imxrt1176 FCB offset address is 0x400, would like to understand why there is a change in imxrt1064, and why not make both consistent to same starting address?
Thank you
标记 (3)
520 次查看
kerryzhou
Hi @djarin
  Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
  Please refer to the newest RT1064RM:
https://www.nxp.com/webapp/Download?colCode=IMXRT1064RM
RT1064 FCB is at the offset 0, don't compare with the RT1170, not the same series chip.
Wish it helps you!
Kerry
521 次查看
kerryzhou
Hi @djarin
Wish it helps you!
Kerry
