Offline flash programmer for i.MX RT1064
etronic_arg
I have successfully implemented an offline programmer using a FRDM-K64F to program a custom board with a K64 based on the AN5331.
Instead of using an SD as a source to load the firmware, I transfer the firmware via Ethernet.
Now I have designed another custom board with a MIMXRT1064. I want to do the same with this board.
I want to use a FRDM-K64 to program the MIMXRT1064 via SWD pins in the same way as before.
I think I need to replace the flash algorithm for the IMX.
How can I get it?
Kan_Li
Hi @etronic_arg ,
This package can only be requested via secure file, please request a higher access right for it. Please kindly refer to https://www.nxp.com.cn/docs/en/user-guide/nxp-secure-access-rights-registration.pdf for details.
Please kindly sigh NDA online according to the following:
Any further access issue , please contact our doc store team via support.docstore@nxp.com with your NDA file.
Hope that helps,
Kan
Kan_Li
Hi @etronic_arg ,
There is a user guide on this topic, please kindly refer to https://www.nxp.com/webapp/Download?colCode=MCUSOPUG for details.
Kan
etronic_arg
Hello Kan,
Thank you for the link.
Is the SPGR project (schematics, source code) available for download?
Pablo
Kan_Li
Hi @etronic_arg ,
Yes, please refer to the following for details.
and you have to access it via the secure file.
Please kindly refer to https://www.nxp.com.cn/docs/en/user-guide/nxp-secure-access-rights-registration.pdf for more details.
Kan
etronic_arg
Hello Kan,
I haven't been able to find the download link you refer to on the NXP website.
Would you mind sending me the link where is the AN14007SW?
Pablo
Kan_Li
Hi @etronic_arg ,
Hope that helps,
Kan
etronic_arg
Thank you!
