yocto down gstreamer
2,879件の閲覧回数
chenps
when I use "repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-gatesgarth -m imx-5.10.9-1.0.0.xml "  to download imx6qsabresd project.  then  an error occurred."ERROR: gstreamer1.0-1.14.4.imx-r0 do_fetch: Fetcher failure for URL: 'gitsm://source.codeaurora.org/external/imx/gstreamer.git;protocol=https;branch=MM_04.05.02_1911_L4.14.98'. Unable to fetch URL from any source."    How can I correct the GStreamer download method?
thanks
3 返答(返信)
2,868件の閲覧回数
joanxie
fetch error is network issue, I suggest that you delete the package and bitbake again
2,861件の閲覧回数
chenps
I can delete  under ~/fsl-release-bsp/build-x11/tmp/work$  about gstreamer path. not  download  gstreamer . later  I can delter   under ~/fsl-release-bsp/build-x11/tmp/work$   and under ~/fsl-release-bsp/sources
about gstreamer path.   but   I cann't l download gstreamer
2,851件の閲覧回数
joanxie
use bitbake -c cleansstate xxx to clean package, then use bitbake to build again
