working with MFI module on imx6qp board
lavakumars
hi everyone.
I am working on imx6qp sabre ai board with yocto version Jethro(2.0.1) and Linux kernel 4.1.15.
Now we are working on I-Pod/phone connection for which we procured MFI module(Apple authentication module) from the apple.
As schematics says this module is accommodated at j46. but the device is not detected in the kernel logs as well system.
Can someone help us how to proceed further..?
Lavakumar S
lavakumars
 hi igorpadykov
 thanks for your help i received Patch.
Apple authentication module not detected on the board (IMX6qp sabre AI board) .
Can you help how to dig?
Ruchi Sirauthiya
Lavakumar S
I sent you additional description using service request,
please check it.
lavakumars
Thanks for your quick response.
does the driver will detect the MFI module itself ? or do we need to tweek something?
because if i use "i2cdetect -y 1" or "i2cdetect -y 2" i cant see the authentication device address though the MFI module (P/N:sp000918596)connected to j46 .
I am getting proper voltages in the j46 pins i.e pin1 : clock;   pin2:Gnd  pin3: pulled up  pin5: 3.3V pin8: pulled up.
and i have connected the iphone to usb hub and checked (usb connected to USB1 j30).
check and help
Lavakumar S
Hi Lavakumar
there is no mfi support in official nxp bsps, suggest to
apply to extended support using NXP Professional Services:
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
Hi Lavakumar
please create service request to obtain patch.
lavakumars
hi  igorpadykov,
Thanks for the reply ,
Can you elaborate a bit.
Lavakumar S
Hi Lavakumar
How to create service request :
https://community.freescale.com/docs/DOC-329745
lavakumars
hi,
Ok I got it .. I raised a request, thanks for the reply .
regards,
Lavakumar S
