Hi, All my dear Friends
I am trying to build androiid jb4.3_1.1.0 using the command
make 2>&1|tee build_sabresd_androoid.log
so, with the above command kernel image created (uImage). But, uboot i.e., (mkimage) is not created and showing some error like below:
make[1]: Leaving directory `/home/salher/IMX_SOURCES/home/calixto/freescale/kernel_imx'
install kernel modules: kernel_imx/drivers/net/wireless/rtl8723as/8723as.ko kernel_imx/net/wireless/cfg80211.ko
make[1]: Entering directory `/home/salher/IMX_SOURCES/home/calixto/freescale/bootable/bootloader/uboot-imx'
make[1]: Leaving directory `/home/salher/IMX_SOURCES/home/calixto/freescale/bootable/bootloader/uboot-imx'
awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend
make: *** No rule to make target `mx6q_sabresd_android_config'. Stop.
make[1]: *** [mx6q_sabresd_android_config] Error 1
System not configured - see README
make[1]: *** [all] Error 1
install: cannot stat `bootable/bootloader/uboot-imx/u-boot.bin': No such file or directory
make: *** No rule to make target `mx6dl_sabresd_android_config'. Stop.
make[1]: *** [mx6dl_sabresd_android_config] Error 1
make: *** [out/target/product/sabresd_6dq/u-boot.bin] Error 1
Please, help me to solve it out.
Kapil Kumar
解決済! 解決策の投稿を見る。
Hi jimmychan
Thanks for your effort to answer my query. I got my problem solved by downloading u-boot source code from the link
git clone git://git.denx.de/u-boot-imx.git // u-boot-imx(this got from https://community.freescale.com/thread/310172)
Are you follow the steps in Android user guide to build the BSP?
Yes.
