MX53-LOCO u-boot and kernel image . Not able to boot till ROOT prompt(Username).
Please help me debug this issue.
On console I'm continuosly getting:
starting pid 2215, tty '': '/sbin/getty -L ttymxc0 115200 vt100'
process '/sbin/getty -L ttymxc0 115200 vt100' (pid 2215) exited. Scheduling for restart.
log obtained uImage :
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 172K
starting pid 1203, tty '': '/etc/rc.d/rcS'
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
Setting the hostname to freescale
Mounting filesystems
cp: write error: No space left on device
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
starting pid 2216, tty '': '/sbin/getty -L ttymxc0 115200 vt100'
process '/sbin/getty -L ttymxc0 115200 vt100' (pid 2216) exited. Scheduling for restart.
starting pid 2217, tty '': '/sbin/getty -L ttymxc0 115200 vt100'
BOOTARGS:
Hit any key to stop autoboot: 3 2 0
MX53-LOCO U-Boot > printenv
bootdelay=3
baudrate=115200
loadaddr=0x70800000
netdev=eth0
ethprime=FEC0
uboot=u-boot.bin
kernel=uImage
nfsroot=/opt/eldk/arm
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
bootcmd_net=run bootargs_base bootargs_nfs; tftpboot ${loadaddr} ${kernel}; bootm
bootcmd=run bootcmd_mmc
ethact=FEC0
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 0;mmc read ${loadaddr} 0x800 0x1800;bootm
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rw rootwait
ethaddr=00:04:9f:01:32:e0
bootargs_base=setenv bootargs console=ttymxc0,115200
stdin=serial
stdout=serial
stderr=serial
cp:write error no space left on device is solved.
changed TMPFS_SIZE = 8192k in etc/rc.d/rc.conf
.But still facing Issue.
starting pid 2215, tty ':'/sbin/getty -L ttymxc0 115200 vt100
process '/sbin/getty -L ttymxc0 115200 vt100'(pid 2215)exited.Scheduling for restart.
Hi omprakash,
Were you able to solve the issue. please let me know. I am also stuck at the same point.
Thanks.
Hello, omprakash!
Please recheck you inittab, rcS and other scripts which run after starting system.
