Dear FSL All
I have met a problem about playing videos by gst-fsl-plugin mfw_isink.
The Detail just like below.
1, OK playing status image with vssconfig-->format=RGBP by mfw_isink
① /usr/share/vssconfig
# vss device definition
# Master=DVI, Slave=TV
# please add "video=video=mxcdi1fb:YUV444,720P60 video=mxcdi0fb:RGB24,1024x768M-16@60" to kernel startup command line
# master display
[master]
type = framebuffer
format = RGBP
fb_num = 1
main_fb_num = 0
② /root/test.sh script
#! /bin/sh
export VSALPHA=1
gst-launch filesrc location=WhereTheHellIsMatt_720p.mp4 typefind=true ! aiurdemux ! vpudec ! mfw_isink axis-top=100 axis-left=100 disp-width=800 disp-height=600
2, Flickering playing status image with vssconfig-->format=RGB3 by mfw_isink
# master display
[master]
type = framebuffer
format = RGB3
fb_num = 1
main_fb_num = 0
#! /bin/sh
export VSALPHA=1
Who can tell me what is the reason about this problem for mfw_isink?
1, When playing the video with screen size set over 640x480(include this size), it must be flickering or strange color.
2, When playing the video screen screen size set less than 640x480, it palys normally and with correct color.
The gst-fsl-plugins' version is 3.0.7
已解决! 转到解答。
Could anyone help for this problem?
All right.
I have just fixed this problem
Reason: mfw_gst_vss_common.c can not supply to convert the RGB24(RGB3) to correct pixel format.
File: gst-fsl-plugins-3.0.7/libs/vss/mfw_gst_vss_common.c
Function: int fmt2bit (unsigned long fmt)
Fixing: Line 147 adding
case IPU_PIX_FMT_RGB24: // added by TongChunyang for fixing the problem of vssconfig set as RGB3
Evidence:
1, bug status log
2, fixed status log
All right.
Evidence:
1, bug status log
2, fixed status log
