make all-recursive
make[1]: Entering directory `/home/archimage/mx28_evk/ltib/rpm/BUILD/libusb-0.1.8'
Making all in .
make[2]: Entering directory `/home/archimage/mx28_evk/ltib/rpm/BUILD/libusb-0.1.8'
if /bin/bash ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -MT usb.lo -MD -MP -MF ".deps/usb.Tpo" \
-c -o usb.lo `test -f 'usb.c' || echo './'`usb.c; \
then mv -f ".deps/usb.Tpo" ".deps/usb.Plo"; \
else rm -f ".deps/usb.Tpo"; exit 1; \
fi
if /bin/bash ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -MT error.lo -MD -MP -MF ".deps/error.Tpo" \
-c -o error.lo `test -f 'error.c' || echo './'`error.c; \
then mv -f ".deps/error.Tpo" ".deps/error.Plo"; \
else rm -f ".deps/error.Tpo"; exit 1; \
fi
if /bin/bash ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -MT descriptors.lo -MD -MP -MF ".deps/descriptors.Tpo" \
-c -o descriptors.lo `test -f 'descriptors.c' || echo './'`descriptors.c; \
then mv -f ".deps/descriptors.Tpo" ".deps/descriptors.Plo"; \
else rm -f ".deps/descriptors.Tpo"; exit 1; \
fi
if /bin/bash ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -MT linux.lo -MD -MP -MF ".deps/linux.Tpo" \
-c -o linux.lo `test -f 'linux.c' || echo './'`linux.c; \
then mv -f ".deps/linux.Tpo" ".deps/linux.Plo"; \
else rm -f ".deps/linux.Tpo"; exit 1; \
fi
./libtool: line 469: CDPATH: command not found
libtool: Version mismatch error. This is libtool 2.4.2, but the
libtool: definition of this LT_INIT comes from an older release.
libtool: You should recreate aclocal.m4 with macros from libtool 2.4.2
libtool: and run autoconf again.
make[2]: *** [error.lo] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [linux.lo] Error 1
make[2]: *** [usb.lo] Error 1
make[2]: *** [descriptors.lo] Error 1
make[2]: Leaving directory `/home/archimage/mx28_evk/ltib/rpm/BUILD/libusb-0.1.8'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/archimage/mx28_evk/ltib/rpm/BUILD/libusb-0.1.8'
make: *** [all] Error 2
error: Bad exit status from /home/archimage/mx28_evk/ltib/tmp/rpm-tmp.42346 (%build)
RPM build errors:
Build time for libusb: 8 seconds
Failed building libusb
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Tue Sep 30 14:27:03 2014
Ended: Tue Sep 30 14:28:44 2014
Elapsed: 101 seconds
These packages failed to build:
libusb
Build Failed
Exiting on error or interrupt
Dear all,
when i build the ltib, I ran into the above question, how should I resolve the problem?
host system: ubuntu 10.04LTS
demo board: i.mx28_evk
已解决! 转到解答。
Hi John
had you installed in Ubuntu libtool package
as described on p.4 Setting_Up_LTIB_Host document ?
Dear igorpadykov,
what you say is below, yes, i have installed 1.5 Install Host Packages Needed by LTIB, however i can build mx6q_sabresd's ltib version completely, but when i build mx28_evk version, i get the error of the topic above.
#!/bin/bash
# Install packages needed by LTIB
sudo aptitude -y install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
sudo aptitude -y install libdbus-glib-1-dev liborbit2-dev intltool
sudo aptitude -y install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
sudo aptitude -y install uuid-dev liblzo2-dev
sudo aptitude -y install tcl dpkg
# Packages required for 64-bit Ubuntu
# Do "uname -a" and see if the word "x86_64" shows up.
if uname -a|grep -sq 'x86_64'; then
sudo aptitude -y install ia32-libs libc6-dev-i386 lib32z1
fi
# The following recommended for Linux development.
# They are not required by LTIB.
sudo aptitude -y install gparted emacs22-nox openssh-server
sudo aptitude -y install nfs-common nfs-kernel-server lintian
sudo aptitude -y install git-core git-doc git-email git-gui gitk
sudo aptitude -y install diffstat indent tofrodos fakeroot doxygen uboot-mkimage
sudo aptitude -y install sendmail mailutils meld atftpd sharutils
sudo aptitude -y install manpages-dev manpages-posix
yes, they can react on each other, ubuntu/ltib may like more newer
libs versions (i.MX6). In general it is not recommended to install different
ltib kernel versions on one Ubuntu.
One can try to install i.MX28 ltib on fresh Ubuntu. You can also look at
https://community.freescale.com/message/314897#314897
~igor
