Hi NXP,
I am trying to port adau1761 to imx8qxp, but get fail when yocto do_copile.
Reference to non-existent node or label "adau1761"
The kernel version is 5.15.
I have already added node "adau1761" like below in imx8x-mek.dtsi.
Please help me :'(
/{....sound-adau1761 {compatible = "simple-audio-card";simple-audio-card,name = "adau1761-Sound-Card";simple-audio-card,format = "left_j";simple-audio-card,bitclock-master = <&codec_dai>;simple-audio-card,frame-master = <&codec_dai>;simple-audio-card,widgets ="Microphone", "Microphone Jack","Headphone", "Headphone Jack","Speaker", "External Speaker";simple-audio-card,routing ="MIC_IN", "Microphone Jack","Headphone Jack", "HP_OUT","External Speaker", "LINE_OUT";cpu_dai: simple-audio-card,cpu {sound-dai = <&sai1>;};codec_dai: simple-audio-card,codec {sound-dai = <&adau1761>;clocks = <&mclkout0_lpcg 0>;};};sound-cs42888 {....};&cm40_i2c {...adau1761: adau1761@3b {compatible = "adi,adau1761";reg = <0x3b>;clocks = <&mclkout0_lpcg 0>;clock-names = "mclk";assigned-clocks = <&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_PLL>,<&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_SLV_BUS>,<&clk IMX_SC_R_AUDIO_PLL_0 IMX_SC_PM_CLK_MST_BUS>,<&mclkout0_lpcg 0>;};};
Solved! Go to Solution.
The problem is because some *-rpmsg.dts delete "cm40_i2c" node.
You have to fix it your way.
