imx8mq missing g2d.h and libg2d
4,748 次查看
terry1
How do I fix this
3 回复数
4,582 次查看
Bio_TICFSL
Hello Terry,
Is probably your yocto do not have gpu? Libg2d and g2d are part of the gpu libs make sure you add it in the building.
regards
4,580 次查看
terry1
In my yocto build I get this.
imx-gpu-g2d was skipped: incompatible with machine imx8mqevk (not in COMPATIBLE_MACHINE)
imx-dpu-g2d was skipped: incompatible with machine imx8mqevk (not in COMPATIBLE_MACHINE)
Any suggestions?
Terry
4,580 次查看
terry1
imx-4.14.98-2.0.1_ga.xml
