Simulation vendor said there is only general package information for ALL pins (accuracy not enough for simulation) in IBIS file <http://www.nxp.com/downloads/en/ibis-model/imx8mm_14x14_v1.zip>. Where can we find SOC package model (the LPDDR4 part at least), typically a SNP file like <http://na.support.keysight.com/plts/help/WebHelp/FilePrint/SnP_File_Format.htm>.
Solved! Go to Solution.
We don't provide SOC package model to customers. Only IBIS model is available.
Yuri.
Link fixed, IBIS file OK. I imported it into our CAD software and did a trial simulation. Thanks
The link for the I.MX8 MINI IBIS file is broken. Anyone have access to
imx8mm_14x14_v1? Thanks, David
Please try
https://www.nxp.com/downloads/en/ibis-model/imx8mm_14x14_v1.zip
~Yuri.
http://external-link.jspa/?url=https%3A%2F%2Fwww.nxp.com%2Fdownloads%2Fen%2Fibis-model%2Fimx8mm_14x1...
Site can’t be reached.
The Web team is informed about the issue. Hope it will be fixed soon.
You may create request \ ticket to get the IBIS file.
Support | NXP
Did last Friday. Confused, was reported that the IBIS file has errors, this isn’t a brand new part.
