imx8mm with DDR3/DDR3LP support under uboot
926 次查看
sebastiansuesen
we will have a customer board with a imx8m mini processor and DDR3LP RAM.
We use yocto with Software Version L4.14.98_2.0.0.  and uboot 2018.03-r0
We know that we get the timing code for uboot by the mscale_ddr_tool.
The uboot basic shall be the imx8mm-evk. I have seen that the uboot supports only DDR4LP/DDR4.
Can you explain how to configure imx8mm-evk board under uboot to get DDR3LP support?
Sebastian
762 次查看
igorpadykov
Hi Sebastian
for ddr3 one can look on
imx8mm_val\freescale\board - uboot-imx - i.MX U-Boot
and check documentation included in https://community.nxp.com/docs/DOC-340179
763 次查看
igorpadykov
Hi Sebastian
