imx8 ddr config
imx8 ddr config
1,281件の閲覧回数
gravity_one
Hello, All
TOOLS:
   MX8QXP_C0_B0_LPDDR4_RPA_1.2GHz_v13.xlsx
   mx8_ddr_stress_test_ER14_installation.zip
BOARD: Imx8qxp mek  DDR stress test
   LPDDR4 3G  --->4G
test log:
MX8 DDR Stress Test Version: ER14
Built on Mar 27 2020 12:28:23
-Set up the MMU and enable I and D cache-
  • This is the Cortex-A35 core
  • Check if I cache is enabled
  • Enabling I cache since it was disabled
  • Push base address of TTB to TTBR0_EL3
  • Config TCR_EL3
  • Config MAIR_EL3
  • Enable MMU
  • Data Cache has been enabled
  • Check system memory register, only for debug
  • VMCR Check:
  • ttbr0_el3: 0x13d000
  • tcr_el3: 0x2051c
  • mair_el3: 0x774400
  • sctlr_el3: 0xc01815
  • id_aa64mmfr0_el1: 0x101122
  • MMU and cache setup complete
ARM Clock(CA35): 1200MHz
DDR Clock: 1200MHz
DDR configuration
DDR type is LPDDR4
Data width: 32, bank num: 8
Row size: 16, col size: 10
Two chip selects are used
Number of DDR controllers used on the SoC: 1
Density per chip select: 2048MB
Density per controller is: 4096MB
Total density detected on the board is: 4096MB
No DDR data training errors detected for DDRC0
MX8QXP: Cortex-A35 is found
DDR Stress Test Iteration 1
-Running DDR test on region 1-
t0.1: data is addr test
t0.2: row hop read test
t1: memcpy SSN armv8_x32 test
t2: byte-wise SSN armv8_x32 test
t3: memcpy pseudo random pattern test
t4: IRAM_to_DDRv1 test
t5: IRAM_to_DDRv2 test
-Running DDR test on region2-
t0.1: data is addr
(Stuck here, didn't know it was wrong, stayed there for 20 minutes, restarted the test many times and still did the same thing)
3 返答(返信)
1,236件の閲覧回数
igorpadykov
Hi Wang
one can recheck "BoardDataBusConfig" settings in RPA tool and
tweak drive strength settings.
1,236件の閲覧回数
gravity_one
hello, igor
I don't know why I pressed the download button of the case. Now it is shown in the picture, and there is no other display
tks
1,236件の閲覧回数
gravity_one
hello, igor
can you tell me how to setting "BoardDataBusConfig"?
only modify
Density per channel per chip select (Gb)1:6
to 8.
tks
