hi,
I have a imx7dsabre board.
I set the BOOTMODE=01 MFG mode.
boot form sd 00100000.
the system can't enter usb download mode, but if I take out the sd card ,the mfg software can find my imx7dsabre board. then I insert the sd card,the usb download program works well.
my imx6slevk board set different mode is works well. Whether the imx7dsabre board has some problem.
Thanks & Best Regards!
Solved! Go to Solution.
Hi yan2
behaviour may be caused by SD/MMC Manufacture Mode, from
sect.6.6.12 SD/MMC Manufacture Mode i.MX7D Reference Manual
http://cache.nxp.com/files/32bit/doc/ref_manual/IMX7DRM.pdf
"..boot will go to SD/MMC manufacture mode before serial download mode..
By default, SD/MMC manufacture mode is enabled
Hi yan2
hi igor,
thanks for you reply. I need to blow the fuse of DISABLE_SDMMC_MFG.
but I can't find the method about how to blow the efuse.
The cmd of imxotp is not exist in my uboot cmd.
Can you give me some help?
yan2anfei
hi igor,
I wan't to disable SDMMC_MFG mode.
I use the fuse cmd of uboot.
but I can't find the bit of DISABLE_SDMMC_MFG from OTP bank0 to bank16.
yan2anfei
please check Table 6-17. Boot Fusemap i.MX7D RM p.1055
fuse Disable SDMMC Manufacture mode
