imx6sl ddr3 failed(yocto)
762件の閲覧回数
indukkim
Hi All,
We got a board with DDR3, we used the spreadsheet for
i.MX6 sololite for generating a DCD table. (imximage.cfg)
Pass the DDR Stress test.
But download failed with the mfgtools. (stop the "Jumping to OS image.)
Detail Info
DDR3 : Samsung KB1G1646G-BCK0
spreadsheet : MX6SL_MMDC_DDR3_register_programming_aid_v0[1].4.xlsx
Build uboot: yocto (u-boot-imx 2013.04-r0)
Please help us.
ラベル(2)
469件の閲覧回数
igorpadykov
Hi Induk
for new board I would suggest to use more mature
and well documented product ltib/mfg tool on link below
IMX_6SL_MFG_TOOL
L3.0.35_4.1.0_ER_SOURCE_BSP :
When board will boot OK with these packages I would recommend
go to yocto.
For new board you should rebuid MFG Tool firmware
(initramfs.cpio.gz.uboot) with new DDR settings.
Check sect.3.8 Building Manufacturing Firmware
i.MX_6SoloLite_EVK_Linux_User's_Guide.pdf
These documents you can find in Doc Bundle below
L3.0.35_4.1.0_LINUX_DOCS
Good starting point would be test board with SDK,
booting with small test inages
i.MX 6Series Platform SDK
chip
