imx6qsabresd/zImage': No such file or directory
1,244件の閲覧回数
Kampi
I try to build a new image for my i.MX SABRE board by using Yocto. I followed the documentation from the NXP Yocto guide, but the process fails with the error
$ bitbake core-image-full-cmdline
Initialising tasks: 100% |##################################################################################################################################################| Time: 0:00:01
Sstate summary: Wanted 5 Local 0 Mirrors 0 Missed 5 Current 1260 (0% match, 99% complete)
Removing 1 stale sstate objects for arch imx6qsabresd: 100% |###############################################################################################################| Time: 0:00:00
NOTE: Executing Tasks
ERROR: core-image-minimal-1.0-r0 do_image_wic: ExecutionError('...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/run.do_image_wic.4100865', 1, None, None)
ERROR: Logfile of failure stored in: ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.4100865
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['...sources/meta-imx/meta-bsp/recipes-bsp/u-boot/u-boot-imx_2023.04.bb:do_populate_sysroot', '...sources/meta-imx/meta-bsp/recipes-security/optee/optee-os_3.21.0.imx.bb:do_populate_sysroot', '...sources/poky/meta/recipes-core/glibc/cross-localedef-native_2.37.bb:do_populate_sysroot', '...sources/poky/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot', '...sources/poky/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', '...sources/poky/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-core/update-rc.d/update-rc.d_0.8.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/apt/apt_2.4.5.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/dosfstools/dosfstools_4.2.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/dpkg/dpkg_1.21.21.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.47.0.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/fdisk/gptfdisk_1.0.9.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/mtools/mtools_4.0.42.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_0.5.0.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-extended/parted/parted_3.5.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-extended/pigz/pigz_2.7.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-extended/zstd/zstd_1.5.4.bb:do_populate_sysroot', 'virtual:native:...sources/poky/meta/recipes-support/bmap-tools/bmap-tools_git.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['u-boot-imx', 'optee-os', 'cross-localedef-native', 'ldconfig-native', 'qemuwrapper-cross', 'depmodwrapper-cross', 'update-rc.d-native', 'apt-native', 'dosfstools-native', 'dpkg-native', 'e2fsprogs-native', 'gptfdisk-native', 'makedevs-native', 'mtools-native', 'opkg-utils-native', 'pseudo-native', 'parted-native', 'pigz-native', 'zstd-native', 'bmap-tools-native', 'perl-native', 'systemd-systemctl-native', 'qemu-native', 'glibc', 'gcc-runtime', 'util-linux-native', 'gettext-minimal-native', 'libtool-native', 'ncurses-native', 'xz-native', 'readline-native', 'texinfo-dummy-native', 'shared-mime-info-native', 'shadow-native', 'popt-native', 'attr-native', 'kmod-native', 'lz4-native', 'zlib-native', 'db-native', 'cmake-native', 'libgcrypt-native', 'xxhash-native', 'gnutls-native', 'python3-installer-native', 'python3-native', 'python3-build-native', 'python3-setuptools-native', 'coreutils-native', 'python3-wheel-native', 'python3-six-native', 'bzip2-native', 'gettext-native', 'libmd-native', 'openssl-native', 'debianutils-native', 'gdbm-native', 'make-native', 'glib-2.0-native', 'linux-libc-headers', 'libgcc', 'libpcre2-native', 'libcap-ng-native', 'util-linux-libuuid-native', 'itstool-native', 'libxml2-native', 'libgpg-error-native', 'libcap-native', 'nettle-native', 'gmp-native', 'p11-kit-native', 'libidn2-native', 'libunistring-native', 'python3-flit-core-native', 'libnsl2-native', 'sqlite3-native', 'libtirpc-native', 'libffi-native', 'python3-pyproject-hooks-native', 'python3-packaging-native', 'libtasn1-native', 'unzip-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing python function set_image_size
| DEBUG: 196955.200000 = 151504 * 1.300000
| DEBUG: 196955.200000 = max(196955.200000, 65536)[196955.200000] + 0
| DEBUG: 196956.000000 = int(196955.200000)
| DEBUG: 196956 = aligned(196956)
| DEBUG: returning 196956
| DEBUG: Python function set_image_size finished
| DEBUG: Executing shell function do_image_wic
| INFO: Creating image(s)...
| ERROR: _exec_cmd: install -m 0644 -D ...build/tmp/deploy/images/imx6qsabresd/zImage ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-full-cmdline/1.0-r0/tmp-wic/boot.2/zImage returned '1' instead of 0
| output: install: cannot stat '...build/tmp/deploy/images/imx6qsabresd/zImage': No such file or directory
| WARNING: ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-full-cmdline/1.0-r0/temp/run.do_image_wic.4081496:161 exit 1 from 'BUILDDIR="...build" PSEUDO_UNLOAD=1 wic create "$wks" --vars "...build/tmp/sysroots/imx6qsabresd/imgdata/" -e "core-image-full-cmdline" -o "$build_wic/" -w "$tmp_wic" --no-fstab-update'
| WARNING: Backtrace (BB generated script):
| #1: do_image_wic, ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-full-cmdline/1.0-r0/temp/run.do_image_wic.4081496, line 161
| #2: main, ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/core-image-full-cmdline/1.0-r0/temp/run.do_image_wic.4081496, line 180
ERROR: Task (...sources/poky/meta/recipes-extended/images/core-image-full-cmdline.bb:do_image_wic) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3691 tasks of which 3663 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message, returning a non-zero exit code.
How can I solve this issue?
6 返答(返信)
1,222件の閲覧回数
Chavira
Hi @Kampi!
The image that are you compiling is not supported by NXP.
I recommend checking the Yocto Project Users Guide in the chapter "5.2 Choosing an i.MX Yocto project image".
Best Regards!
Chavira
1,212件の閲覧回数
Kampi
thank you. That was my first thought too, so I tried different images from the documentation, but the error still existed.
$ bitbake fsl-image-machine-test
Loading cache: 100% |#######################################################################################################################################################| Time: 0:00:00
Loaded 5306 entries from dependency cache.
Parsing recipes: 100% |#####################################################################################################################################################| Time: 0:00:00
Parsing of 3444 .bb files complete (3443 cached, 1 parsed). 5307 targets, 660 skipped, 17 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "2.4.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "imx6qsabresd"
DISTRO = "fsl-imx-wayland"
DISTRO_VERSION = "6.1-mickledore"
TUNE_FEATURES = "arm vfp cortexa9 neon thumb callconvention-hard"
TARGET_FPU = "hard"
meta
meta-poky = "HEAD:ddb298ce894482467d82699d223c5555baad6591"
meta-oe
meta-multimedia
meta-python = "HEAD:54b177f4acb3048d21a68f180fc183d0fdf47a94"
meta-freescale = "HEAD:39d8f0d5ee44aae9932923e9fe95b7f2838563af"
meta-freescale-3rdparty = "HEAD:48cc5dd42007d09295677bc8bc0377fe96b5b270"
meta-freescale-distro = "HEAD:a4efa17a9f6b25d8d9290dfee8275059d40b83df"
meta-bsp
meta-sdk
meta-ml
meta-v2x = "HEAD:64a864ab77de06a557afcb01e6dd4d21606e6948"
meta-nxp-demo-experience = "HEAD:ec9d5592dc6369622dc027ad456cadb844451226"
meta-arm
meta-arm-toolchain = "HEAD:0b5724266a8e559cac1724350c1ff2f9e6580326"
meta-chromium = "HEAD:e232c2e21b96dc092d9af8bea4b3a528e7a46dd6"
meta-clang = "HEAD:1e0af2f5bb797d7bb639c2ac03c1248cc8d00bc9"
meta-gnome
meta-networking
meta-filesystems = "HEAD:54b177f4acb3048d21a68f180fc183d0fdf47a94"
meta-qt6 = "HEAD:1406d0a85525a71fe5d7892d7f915404290a78ad"
meta-parsec
meta-tpm = "HEAD:d7db0a3bd1a8639df7570483f003ce00cbe274a2"
meta-virtualization = "HEAD:2bb4071ad372d4b5a092c872c0d42b261f757681"
Initialising tasks: 100% |##################################################################################################################################################| Time: 0:00:02
Sstate summary: Wanted 7 Local 0 Mirrors 0 Missed 7 Current 2893 (0% match, 99% complete)
ERROR: fsl-image-machine-test-1.0-r0 do_image_wic: ExecutionError('...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/temp/run.do_image_wic.4133797', 1, None, None)
ERROR: Logfile of failure stored in: ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/temp/log.do_image_wic.4133797
Log data follows:
| NOTE: Installed into sysroot: ['dosfstools-native', 'gptfdisk-native', 'mtools-native', 'parted-native', 'popt-native']
| NOTE: Skipping as already exists in sysroot: ['u-boot-imx', 'optee-os', 'cross-localedef-native', 'ldconfig-native', 'qemuwrapper-cross', 'depmodwrapper-cross', 'update-rc.d-native', 'apt-native', 'dpkg-native', 'e2fsprogs-native', 'makedevs-native', 'opkg-utils-native', 'pseudo-native', 'pigz-native', 'zstd-native', 'bmap-tools-native', 'qemu-native', 'systemd-systemctl-native', 'shadow-native', 'gcc-runtime', 'glibc', 'ncurses-native', 'util-linux-native', 'kmod-native', 'debianutils-native', 'openssl-native', 'glib-2.0-native', 'gdk-pixbuf-native', 'texinfo-dummy-native', 'libtool-native', 'gettext-native', 'xz-native', 'libmd-native', 'bzip2-native', 'gettext-minimal-native', 'zlib-native', 'perl-native', 'attr-native', 'python3-installer-native', 'python3-six-native', 'python3-native', 'python3-setuptools-native', 'coreutils-native', 'python3-build-native', 'python3-wheel-native', 'lz4-native', 'db-native', 'cmake-native', 'gnutls-native', 'xxhash-native', 'libgcrypt-native', 'shared-mime-info-native', 'readline-native', 'gtk+3-native', 'libgcc', 'linux-libc-headers', 'util-linux-libuuid-native', 'libpcre2-native', 'libcap-ng-native', 'libffi-native', 'libpng-native', 'libjpeg-turbo-native', 'gobject-introspection-native', 'make-native', 'gdbm-native', 'python3-flit-core-native', 'libtirpc-native', 'sqlite3-native', 'libnsl2-native', 'python3-pyproject-hooks-native', 'python3-packaging-native', 'gmp-native', 'libunistring-native', 'p11-kit-native', 'nettle-native', 'libidn2-native', 'libcap-native', 'libgpg-error-native', 'libxml2-native', 'itstool-native', 'libxrandr-native', 'libxcursor-native', 'libx11-native', 'libxi-native', 'at-spi2-core-native', 'libxext-native', 'libxfixes-native', 'pango-native', 'libxcomposite-native', 'libxrender-native', 'fontconfig-native', 'libxdamage-native', 'cairo-native', 'flex-native', 'unzip-native', 'libtasn1-native', 'util-macros-native', 'xorgproto-native', 'libxcb-native', 'xtrans-native', 'dbus-native', 'libxtst-native', 'freetype-native', 'harfbuzz-native', 'fribidi-native', 'libxft-native', 'expat-native', 'libsm-native', 'pixman-native', 'm4-native', 'libpthread-stubs-native', 'libxau-native', 'xcb-proto-native', 'libxdmcp-native', 'icu-native', 'libice-native', 'gnu-config-native']
| DEBUG: 1657390.800000 = 1274916 * 1.300000
| DEBUG: 1657390.800000 = max(1657390.800000, 65536)[1657390.800000] + 0
| DEBUG: 1657391.000000 = int(1657390.800000)
| DEBUG: 1657391 = aligned(1657391)
| DEBUG: returning 1657391
| ERROR: _exec_cmd: install -m 0644 -D ...build/tmp/deploy/images/imx6qsabresd/zImage ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/tmp-wic/boot.2/zImage returned '1' instead of 0
| WARNING: ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/temp/run.do_image_wic.4133797:161 exit 1 from 'BUILDDIR="...build" PSEUDO_UNLOAD=1 wic create "$wks" --vars "...build/tmp/sysroots/imx6qsabresd/imgdata/" -e "fsl-image-machine-test" -o "$build_wic/" -w "$tmp_wic" --no-fstab-update'
| #1: do_image_wic, ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/temp/run.do_image_wic.4133797, line 161
| #2: main, ...build/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-machine-test/1.0-r0/temp/run.do_image_wic.4133797, line 180
ERROR: Task (...sources/meta-freescale-distro/recipes-fsl/images/fsl-image-machine-test.bb:do_image_wic) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6951 tasks of which 6941 didn't need to be rerun and 1 failed.
1,195件の閲覧回数
Chavira
Hi @Kampi!
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
Best Regards!
Chavira
1,187件の閲覧回数
Kampi
Hi @Chavira
sorry I didn´t understand it...
Table 1 is listing the fsl-image-machine-test image. So why isn´t it supported?
1,180件の閲覧回数
Chavira
Hi @Kampi !
That image was created by the community not directly by NXP.
For that case, I recommend deleting your actual Yocto project and compiling the "imx-image-core" image if you want only the terminal in your board
Best Regards!
Chavira
1,144件の閲覧回数
Kampi
I found a solution by removing the complete directory and rebuilding everything again.
