I buy the new imx6q AI board (Rev C), it is red color.
But i found that with this cpu board, touchscreen is not work.(I use the lastest BSP).
Is there anyone have already confirm the touchscreen of rev C imx6q AI cpu board?
Thank you!
解決済! 解決策の投稿を見る。
Hello, Mr Gao:
There was one known hardware issue which may impact touch screen interrupt.
Some information are FYI:
Applies to CPU Cards: MCIMX6QAICPU1 and MCIMX6DLAICPU1
Defect Description
The processor never receives the LVDS touch panel interrupt. A buffer has its power pin unconnected.
Resolution
Connect interrupt buffer U1514 pin 5 to power rail P3V3_DELAYED.
Hello, Mr Gao:
Defect Description
Resolution
Thank you very much.
I had close this issue follow your resolution.
And I think it's better to update this to freescale's documents.
Many of my customers haven't know about this.
Thank you.
The document is now available on Community. See SABRE-AI_Touch_Int_Bulletin_v1.pdf.
We are working on the document. Thank you for your feedback.
Glad to see it's helpful.
I will consult with hardware team whether this information was published into the formal document.
We are working on the document. It will be released soon. I will tell the customer.
