imx6 YUV422 10bit capture on mipi
682 次查看
guffigubber
Hi to All.
I have an imx6 processor. As well as a camera with a mipi output (2 lines, YUV422 10 bit).
I have no problem setting up 8 bit capture. But I need to capture 10 bits.
I didn't find anything in the docs on how to set it up.
I need help.
Maybe there are some solutions?
标记 (3)
560 次查看
guffigubber
We consider the issue closed. The camera manufacturer has given incorrect data parameters.
652 次查看
joanxie
did you use BT656?you can set csi format as 8bit format still,because IPU only can handle 8bits mode internally
561 次查看
guffigubber
