Hi to All.
I have an imx6 processor. As well as a camera with a mipi output (2 lines, YUV422 10 bit).
I have no problem setting up 8 bit capture. But I need to capture 10 bits.
I didn't find anything in the docs on how to set it up.
I need help.
Maybe there are some solutions?
Solved! Go to Solution.
did you use BT656?you can set csi format as 8bit format still,because IPU only can handle 8bits mode internally
