imx6 YUV422 10bit capture on mipi
guffigubber
Hi to All.
I have an imx6 processor. As well as a camera with a mipi output (2 lines, YUV422 10 bit).
I have no problem setting up 8 bit capture. But I need to capture 10 bits.
I didn't find anything in the docs on how to set it up.
I need help.
Maybe there are some solutions?
Tags (3)
guffigubber
We consider the issue closed. The camera manufacturer has given incorrect data parameters.
joanxie
did you use BT656?you can set csi format as 8bit format still,because IPU only can handle 8bits mode internally
guffigubber
