imx287 GPIO default value
719件の閲覧回数
adityapatil
hi,
1. I am working on imx287 custom board using Linux-2.6.35.3
2. How can I keep the gpio value to be low by default.
3. After Restart my gpio are at high state 3.3v
-Thanks
Aditya
ラベル(2)
591件の閲覧回数
Bio_TICFSL
Hi Aditya,
You can program the GPIO at the initialization of the board it takes minimun time.
First you need to export the GPIO you want to test to the user space:
echo XX > /sys/class/gpio/export
XX shall be determined by the following algorithm:
GPIOA_[B] is the GPIO you want to export, where "A" is the GPIO bank and "B" is the offset of the pin in the bank. if the first available GPIO bank is 0 // (iMX.28, for example)     XX = A*32 + B; else // first GPIO bank is 1     XX = (A-1)*32 + B;
