iMX93 OpenWrt make error: atf-imx
3,465 次查看
AlanWen
I follow the nxp-imx/imx_openwrt git to build a custom image but I encounter a make error.
In make menuconfig, I changed the top 3 items for specific board (i.MX93) as shown below.
After configuring, I start making the image result, and I get a make error as shown below.
Could anybody help me fix this issue?
Thanks.
标记 (4)
5 回复数
3,098 次查看
hao_zhou
you can use sudo make -j4 V=sc E=0 package/boot/atf-imx/compile TF_LDFLAGS="--no-warn-rwx-segments"  or modify your tf ldflags  to compile
3,188 次查看
alm77
I have the same error with atf-imx, were you able to solve it?
3,264 次查看
yangh94
Hello, I have the same problem. Have you solved it?
thank you
3,098 次查看
hao_zhou
3,418 次查看
joanxie
