iMX8: M4 stops running on A53 reset
1,519 次查看
takahisa_tanaka
Hello
I experienced that M4 stops running, after a 'reboot' command on A53.
According to the thread below, after reset, A7 will reconfigure the clocks on which M4 is depending and this may cause unknown behaviors.
iMx7: M4 stops running on A7 reset
https://community.nxp.com/thread/442858
Does A53, like A7, reconfigure the clock on which M4 is depending?
Takahisa Tanaka
4 回复数
1,322 次查看
igorpadykov
Hi Takahisa
yes
1,322 次查看
takahisa_tanaka
Hi Igor,
When I was investigating the code in imx-atf in another matter, I noticed that the reboot command would not stop M4, because the reboot command fires the watchdog(timeout 500ms) and does a full reset.
When I reviewed my test environment, the RTOS image was not loaded on M4 after reboot due to a U-boot misconfiguration.
Sorry, i.MX8 does not stop M4 after reboot.
Takahisa Tanaka
1,322 次查看
takahisa_tanaka
Hi Igor,
No. I was mistaken in my understanding. M4 stops running on A53 reset.
Executing the reboot command takes a full reset with watchdog, so M4 boots after it stops.
Sorry for the confusion.
Takahisa Tanaka
1,322 次查看
takahisa_tanaka
Hi igor
Thank you for your quick response!
Takahisa Tanaka
