I just want to clarify what the final routed length of this trace needs to be. AN4215 specifies that the total routed length needs to be
CLK routed distance + DQS routed distance.
I have 2 byte lanes in my DDR2 interface so I have DQS0 and DQS1.
I want to confirm what the correct interpretation is. Is it...
total routed length = CLK + DQS0 + DQS1
or
total routed length = CLK + (DQS0 or DQS1)
I believe that the latter is correct....
Thanks in advance.
解決済! 解決策の投稿を見る。
HI Nicholas
best value would be the middle value between the two lengths
mean ( EMI_CLK+EMI_CLKn , DQS0+DQS0n, DQS1+DQS1n )
HI Nicholas
Thanks! Your solution is close to my 2nd interpretation though more accurate than using one or the other (keeping in mind that my CLK and DQS traces are all equal in length to within 50 mils.)
