iMX mini uboot hangs
738件の閲覧回数
kajolkharbanda
i am trying to access PCI address space in imx8mmevk board using md command,
the u-boot hangs after typing this command,
i was expecting to see the device id and vendor id as this is PCI base address
u-boot # md  0x33800000
is it not possible to see the PCI address space using read command from u-boot.
6 返答(返信)
725件の閲覧回数
joanxie
I checked the uboot source code, it seems uboot doesn't enable pcie, you can use memtool in the kernel when board boot up to read the register
714件の閲覧回数
kajolkharbanda
i need to access the pci from u-boot.
Can i enable PCI from u-boot ?
703件の閲覧回数
joanxie
check the mail pls
698件の閲覧回数
kajolkharbanda
Thanks, how to build u-boot and flash it ?
682件の閲覧回数
joanxie
you can use uuu tools or dd command to flash uboot to the emmc or sd card, more detailed information, pls refer to the user guide
577件の閲覧回数
kajolkharbanda
the uboot patch you gave me seems to be incompatible with my BSP
i.MX Linux Yocto Project BSP 6.1.22_2.0.0 Release
