i.mx6DL cant send data through UART2,3.
644 次查看
ispark
Target environment is Android 4.4.2 .
I installed UART2,3 with tested i.mx6Q quad processor without problem.
device is /dev/ttymx1, /dev/ttymx2
But processor MCimx6U5DVM10AC board can not run UART 2, 3 .
So question is I.mx6DL processor UART port has difference with Quad processor?
542 次查看
ispark
thanks for your response.
it was corrected by port pin mapping change.
542 次查看
igorpadykov
Hi IS
DL has different than DQ registers addresses, also suggest to
look at attached Porting Guide Chapter 3 Registering a New UART Driver
