HI All,
iam doing ddr3 stress test to imx6 solo board..here i am getting this error everytime..
https://community.nxp.com/servlet/JiveServlet/downloadBody/94917-102-14-285076/I.
https://community.nxp.com/servlet/JiveServlet/download/339795-1-419286/DDR_Stress_
loop: 1
DDR Freq: 396 MHz
t0.1:data is addr test
address of failure:0x30000000
data was:0x03000024
but pattern should match address
please give me some guidance for how to run ddr stress test successfully..!
thanks & regards,
srikrishna
please check if Your PCB design satisfies recommendations of the HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL:
In particular, use the sheet, named "MX6 DRAM Bus Length Check".
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
thank you @Yuri Muhin for giving such guidance..
again i am facing the same issue .,a small doubt on this that i.mx6 solo board stress test already done successfully before 4 months ..
so i'm trying to do again on this board is that will give the same result or i have to go with a new board..!
best regards,
srikrishna.
perhaps it makes sense to perform memory calibration again and use its
results in the initialization code.
Yuri.
