HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL
This is a HW design checklist for customer's reference.
Please read and fill it in carefully before requesting a schematic review.
Rev3.1 @2016.10.19 --
1. Add i.MX6DQP related contents.
添付
コメント
You should use the officially posted H/W Developers Guide on te Freescale website - you will find the IMX6DQ6SDLHDG under the "User Guides" subdirectory at
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6Q&fpsp=1&tab=Documentation_Tab
This is a summary based on IMX6DQ6SDLHDG and our supporting experience.
It is convenient for customer using!
I'm trying to use this check list for my design and the data bus in the "MX6 DRAM Bus Length Check" tab fails because of the L0 values for DRAM_D48 to DRAM_D63 are filled with values over 300.  That seems a lot, considering that all the other pins are set to 0.   Are the L0 values set up correctly in the spreadsheet? Our layout is almost identical to the Freescale reference platform.
Hi Rowlan,
Thanks for your comments!
It is a bug, I had fixed it and updated.
All L0 should be zero in the excel.
Thanks Lin!
The other problem we have is CKE0, on the Freescale reference platform CKE0 is shorter than the other nets in its group and does not seem to be tuned.  Any ideas why?
Hi Rowland,
I think CKE0 related timing requirement are not tight, so It is not critical for layout.
Do you agree?
Yes, I looked at the memory datasheet and I think you are right.
Thanks for your help.
We have a custom IMX6Q board.  We boot from SD3/4-bit, using BOOT_CFG1[7:0]= 0100 0000; and BOOT_CFG2[7:0]= 0011 0000.  Our board doesn't boot up consistently from SD3- if we reset it (POR_B=0) repeatedly, it may or may not boot up.  When it doesn't boot up, we can run the DDR stress test over USB so the IMX6Q is still functional.
This problem can't be the ERR006282 errata because it's too frequent.
This spreadsheet mentions a "MMC/SD boot failure", and I think it refers to setting BOOT_CFG2[2] high to do a DLL override?  Is this new errata?  Anyone have more details?
Thanks.
The item in spreadsheet is related with actual SD bus layout and the failure may happen during bad SI design and very long bus is applied.
Please create a separate question in community with related info showed(0x450[10] status and chip version).
Hi Wang Lin, regarding the added comment - Please keep i.Mx6 "SDx_RESET" pin connecting properly with device reset pin  when eMMC/SD fast boot is used in a design (Latest silicon version had fixed this issue, don't need consider this item.), do you know exactly from which silicon version onwards has this issue been fixed?
After checking, this fix was applied on i.MX6DQ AC and i.MX6SDL AB.
Normally i.MX6SDL will be 1 version lower than its i.MX6DQ equivalent, i.e. normally i.MX6DQ "C” version corresponds to the i.MX6SDL "B” version.  Thanks for checking.
Sorry, my mistake, it should be "AB" for i.MX6SDL.
Thanks!
The DRAM lenght tab is interresting but why keep all L0 to 0 ?
I got the internal wiring length for both PBGA and FCBGA and they do vary, I think we should take this inyo account and have a tab for each package and maybe increase tolerance to match Hardware Development Guide.
Thanks, Philippe.
Yes,you catch the point.
That's the reason why we define a very strict equal length rules.
Based on simulation analysis and real test result, the rules are robust to meet the requirement using PBGA and FCBGA on same PCB design.
We believe most of our customer don't care L0 but only the stability and performance.
LinWang    I preferred the previous spreadsheet for customer to select Yes, No, Not Sure instead of the newer Clear, Not Sure.
Having the No as default forced customer to change to Yes therefore I knew they actually read the checkpoint.
Can you see if this can be changed back?
Brett Phagan
  I refer to "HW Design Checking List for i.Mx6DQSDL Rev2.7" for DRAM Bus length Check of my layout, but I found control group should only have CKE/CS/ODT, cannot include RAS/CAS/WE, I also refer to Intel and "IMX6DQ6SDLHDG_Hardware Development Guide" that the documents also describe Control signals only have CS/CKE/ODT, why does control group include RAS/CAS/WE in the "HW Design Checking List for i.Mx6DQSDL Rev2.7" and compare the trace length<=25mil?
Jasper Chen.
Hi Jasper,
Please check checking list and HDG carefully, we list RAS/CAS/WE in another row of table.
trace length rules are defined for timing control.
Hi LinWang:
I check it carefully, that's why I can find the different between HDG and HW design checking list of Freescale documents, so Freescale any recommend for the different? follow HDG or checking list?
Thanks and best regards,
Jasper.
Hi Jasper,
Sorry, would you please capture a picture and show the different to me?
I believe it is same between checking list and HDG on this part.
Thanks!
Hi LinWang:
     Please see "Hardware Develop Guide for i.MX6Dual/6Quad and i.MX 6Solo/6DualLite Applications Precessors, Rev. 1" page3-8 Table3-3. DDR3 routing by byte group as below Pic1/2.
Pic1.
Pic2.
Pic3. from HW Design Checking List for i.Mx6DQSDL Rev2.7: MX6 DRAM Bus Length Check.
Jasper.
Hi Jasper,
If you mean CS1/ODT1/CKE1, the reason is most application only use one CS, so the self checking table didn't include another CS related signals.
If you will use two CS, all signals should follow the rule.
if you mean Address and BA, you can find them in the top side of table.
Hi LinWang:
I mean RAS/CAS/WE should compare with Address signals and not compare with control group whatever CS[0:1]/ODT[0:1]/CKE[0:1] from Intel and Freescale HDG.
But why RAS/CAS/WE signal compare with control group in the checking list?
Jasper.
Hi Jasper,
All address and control signals should compare with clock length.
it is aligned in table and excel.
Please check.
Hi LinWang,
     I know all address and control signals must compare with clock length, but why RAS/CAS/WE also compare with CKE/CS/ODT in the checking list, not compare with address?
Please confirm~
Hi Jasper,
After checking,
Both RAS/CAS/WE and CKE/CS/ODT in the checking list are compare with clock, not others.
Hi LinWang,
     But HDG describe RAS/CAS/WE should compare with clock and address signals, not control signal(CKE/CS/ODT).
Why?
Please confirm again~
I can't understand why you say HDG " describe RAS/CAS/WE should compare with clock and address signals".
all signals are compare with clock in HDG and checking list.
Hi LinWang,
  Please just focus on command and control signals.
The HDG recommend command signals compare with clock and address signals.
But the checking list recommend command signals compare with control and clock signals, not compare with address and clock signals.
The two documents description is different, please check~
Please help to capture picture here.
Thanks!
Please see above reply from me, Pic1/2/3.
chen jasper   2014/10/14 下午 9:11  (回應 LinWang)
LinWang,
I think the wording of the question is not clear.
In the HDG, you have Address, RAS,CAS,SDBA and SDWE listed together. They have a min max related to clock. But they also have a +/- 25 mils to each other. See last column.
CS, SDCKE and SDODT are grouped together with min max to clock. They also have a +/- 50 mils dependency to each other.
Are there any dependencies between the 2 groups?
Is the to groups of signals completely independent of each other?
One can be near max clock and the other group near min clock?
Brett
Hi LinWang,
My question is
In the HDG define: Command signals(RAS/CAS/WE) compare with "address signals" and clock signals.
In the MX6 DRAM Bus Length Check sheet of HW Design checking list define: Command signals(RAS/CAS/WE) compare with "control signals" and clock signals.
Which one is correct?
Hi Brett,
[WL] no, don't need.
[WL] yes for board level timing control.
[WL] clock only have +/-5mil different. so That will not bring and big different.
Please check table header define.
"control signals" is group name.
I should have been clearer on the third question:
Can one group be close to Clock-200 and the other group be close to Clock since each group has those listed as min max?
Yes,
For CS/ODT/CKE group isn't involved into read write high speed operation, so we don't need consider them so tight.
hi LinWang
Similar Hw Design Checking list document for the SoloLite Processors is available as well ?
--Pankaj Rana
Hi Pankaj Rana,
Sorry, we don't have a excel version checking list.
Please refer to i.MX6SL HDG.
There is checking list table in it.
Hi LinWang,
I have a question about Ref7 of the design checking list.
It says as below.
<Ref7>
To minimize current drain, the Freescale BSP (board-support package) disables the EMI I/O during DSM (deep-sleep mode). A pull-down resistor ensures that the DRAM is in the proper state during DSM.
• For LPDDR2: SDCKE[1:0] must be pulled down to meet the JEDEC sequence until the controller is
configured and starts driving.
• For DDR3: SDCKE[1:0] pull-down is not required to meet JEDEC.
According to this description, I understood a external pull-down resistor is not required for DDR3 because i.MX6 output low signal to SDCKE properly when DDR3 SDCKE has to be low (e.g. when deep sleep, reset, etc..) even though there is no external pull-down.
Is my understanding correct?
Satoshi Shimoda
Hi Satoshi,
Sorry for late response due to holiday.
The key point is if JEDEC require low during power on, for DDR3 RESET pin is required and for LPDDR2 CKE pin is required.
i.MX6 IO internal pull down resistor can't guarantee low during power up, that's why need external pull down resistor.
Hope above explanation can help you.
Hi LinWang,
Thank you for your reply.
OK, I understood a external resistor is needed for DDR3 RESET, but not needed for DDR3 SDCKE to meet JEDEC.
For DDR3 RESET, Hardware Development Guide official revision (Rev.1) says "Connect DRAM_RESET to a 10 kΩ 5% pulldown resistor to GND.", so it is no problem.
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf?fasp=1&WT_TYPE=Users%20Guide...
Satoshi Shimoda
Hi LingWang,
Sorry, one more question.
According to JEDEC, CKE should to be "low" min 10ns before negate DRAM_REST_B.
Can i.MX6 pull down CKE to low even though during power up?
Satoshi Shimoda
Sure, DRAM_RESET_B is also controlled by  i.MX6, so we can guarantee the timing.
Hi Lin,
Does any max layout length in those pin ?
USDHC
SD/MMC USDHC-2
SD3 USDHC-3
PCIE
CLK1_N
CLK1_P
PCIE_RXM
PCIE_RXP
PCIE_TXM
PCIE_TXP
RGMII for Ethernet
RGMII_TXC
RGMII_RD1
RGMII_RD2
RGMII_RD3
RGMII_RX_CTL
RGMII_RXC
RGMII_TD0
RGMII_TD1
RGMII_TD2
RGMII_TD3
RGMII_TX_CTL
USB
USB_H1_DP
USB_H1_DN
USB_OTG_DN
USB_OTG_DP
MIPI
DSI
CSI
CSI0
Apollo Chang
Hi Apollo,
It is hard to define a max rule for these ports.
Because they are depended on real working speed and actual PCB design, SI performance should be considered case by case.
Please refer to FSL reference design for your consideration and suggest to do post simulation with SI simulation tool.
Hope above info can help you.
Hi WangLin,
Any H/W checking lsit for i.MX6SoloX??
Carl
Hi Carl,
Sorry, currently it is not available.
Please refer to other 6 series checking list first.
Hi Lin,
Can you add
"Freescale i.MX6 "Fly by" DRAM PCB Layout Trace Length Calculation  "
into excel file ?
Hi Apollo,
Except clock length have no upper limit, all rules are same with T topology.
Fly-by is a common design in PC system, we can get general design rules through internet.
%3CLINGO-SUB%20id%3D%22lingo-sub-1100383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEHW%E8%A8%AD%E8%A8%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E7%95%A5%E5%9B%B3%E3%81%AE%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%82%92%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%82%88%E3%81%8F%E8%AA%AD%E3%82%93%E3%81%A7%E8%A8%98%E5%85%A5%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%94%B9%E8%A8%82%E7%89%883.1%20%40%202016.10.19%20--%3C%2FP%3E%3CP%3E1.%20i.MX6DQP%E9%96%A2%E9%80%A3%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1100383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEHW%E8%A8%AD%E8%A8%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E7%95%A5%E5%9B%B3%E3%81%AE%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%82%92%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%82%88%E3%81%8F%E8%AA%AD%E3%82%93%E3%81%A7%E8%A8%98%E5%85%A5%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%94%B9%E8%A8%82%E7%89%883.1%20%40%202016.10.19%20--%3C%2FP%3E%3CP%3E1.%20i.MX6DQP%E9%96%A2%E9%80%A3%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DualPlus6QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDDR%E3%81%AE%E9%95%B7%E3%81%95%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%20L0%20%E3%81%A8%20L1%20%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E8%AA%AC%E6%98%8E%E4%BB%98%E3%81%8D%E3%81%AE%E5%9B%B3%E9%9D%A2%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlex%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Apollo%2C%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%95%B7%E3%81%AB%E4%B8%8A%E9%99%90%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E9%99%A4%E3%81%91%E3%81%B0%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AFT%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%81%AFPC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E8%A8%AD%E8%A8%88%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E8%A8%AD%E8%A8%88%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Lin%2C%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%22%3C%2FTD%3E%3CTD%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%20%22Fly%20by%22%20DRAM%20PCB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%83%BB%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E9%95%B7%E8%A8%88%E7%AE%97%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3EExcel%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Carl%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E4%BB%96%E3%81%AE6%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20WangLin%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6SoloX%E3%81%AEH%2FW%E3%83%81%E3%82%A7%E3%83%83%E3%82%AFlsit%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Apollo%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%8B%95%E4%BD%9C%E9%80%9F%E5%BA%A6%E3%81%A8%E5%AE%9F%E9%9A%9B%E3%81%AEPCB%E8%A8%AD%E8%A8%88%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81SI%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AF%E3%82%B1%E3%83%BC%E3%82%B9%E3%83%90%E3%82%A4%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFSL%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%92%E3%81%94%E6%A4%9C%E8%A8%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81SI%20%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9D%E3%82%B9%E3%83%88%20%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Lin%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E6%9C%80%E5%A4%A7%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E9%95%B7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E6%96%B0%E7%B4%B0%E6%98%8E%E9%AB%94'%2C'serif'%3B%20color%3A%20black%3B%22%3E%3CSTRONG%3EUSDHC%E3%81%AE%3C%2FSTRONG%3E%3CBR%20%2F%3E%20SD%20%2F%20MMC%20USDHC-2%3CBR%20%2F%3E%20SD3%20USDHC-3%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSTRONG%3EPCIE%E3%81%AE%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%20CLK1_N%3CBR%20%2F%3E%20CLK1_P%3CBR%20%2F%3E%20PCIE_RXM%3CBR%20%2F%3E%20PCIE_RXP%3CBR%20%2F%3E%20PCIE_TXM%3CBR%20%2F%3E%20PCIE_TXP%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E7%94%A8%E3%81%AERGMII%3C%2FSTRONG%3E%3CBR%20%2F%3E%20RGMII_TXC%3CBR%20%2F%3E%20RGMII_RD1%3CBR%20%2F%3E%20RGMII_RD2%3CBR%20%2F%3E%20RGMII_RD3%3CBR%20%2F%3E%20RGMII_RX_CTL%3CBR%20%2F%3E%20RGMII_RXC%3CBR%20%2F%3E%20RGMII_TD0%3CBR%20%2F%3E%20RGMII_TD1%3CBR%20%2F%3E%20RGMII_TD2%3CBR%20%2F%3E%20RGMII_TD3%3CBR%20%2F%3E%20RGMII_TX_CTL%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSTRONG%3EUSB%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20USB_H1_DP%3CBR%20%2F%3E%20USB_H1_DN%3CBR%20%2F%3E%20USB_OTG_DN%3CBR%20%2F%3E%20USB_OTG_DP%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CSTRONG%3EMIPI%3C%2FSTRONG%3E%E3%81%AE%3CBR%20%2F%3E%20DSI%E3%81%AE%3CBR%20%2F%3E%20CSI%E3%81%AE%3CBR%20%2F%3E%20CSI0%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%9D%E3%83%AD%E3%83%BB%E3%83%81%E3%83%A3%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81DRAM_RESET_B%E3%82%82i.MX6%E3%81%A7%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E4%BF%9D%E8%A8%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFLingWang%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26gt%3B%20i.MX6%20IO%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E3%83%AD%E3%83%BC%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJEDEC%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81CKE%E3%81%AFDRAM_REST_B%E3%82%92%E5%90%A6%E5%AE%9A%E3%81%99%E3%82%8B10ns%E4%BB%A5%E4%B8%8A%E5%89%8D%E3%81%AB%E3%80%8C%E4%BD%8E%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AF%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%A7%E3%82%82%20CKE%20%E3%82%92%20Low%20%E3%81%AB%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESatoshi%20Shimoda%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20LinWang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DDR3%20RESET%E3%81%AB%E3%81%AF%E5%A4%96%E9%83%A8%E6%8A%B5%E6%8A%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81DDR3%20SDCKE%E3%81%8CJEDEC%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EDDR3%20RESET%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AC%E3%82%A4%E3%83%89%E6%AD%A3%E5%BC%8F%E6%94%B9%E8%A8%82%E7%89%88(Rev.1)%E3%81%AB%E3%80%8C10k%CE%A9%205%25%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%ABDRAM_RESET%E3%82%92GND%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%8D%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fuser_guide%2FIMX6DQ6SDLHDG.pdf%3Ffasp%3D1%26amp%3BWT_TYPE%3DUsers%2520Guides%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dpdf%26amp%3BWT_ASSET%3DDocumentation%26amp%3BfileExt%3D.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fuser_guide%2FIMX6DQ6SDLHDG.pdf%3Ffasp%3D1%26amp%3BWT_TYPE%3DUsers%2520Guides%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dpdf%26amp%3BWT_ASSET%3DDocumentation%26amp%3BfileExt%3D.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fuser_guide%2FIMX6DQ6SDLHDG.pdf%3Ffasp%3D1%26amp%3BWT_TYPE%3DUsers%2520Guides%26amp%3BWT_VENDOR%3DFREESCAL%E2%80%A6%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESatoshi%20Shimoda%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Satoshi%2C%3C%2FP%3E%3CP%3E%E4%BC%91%E6%97%A5%E3%81%AE%E3%81%9F%E3%82%81%E5%AF%BE%E5%BF%9C%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%87%8D%E8%A6%81%E3%81%AA%E7%82%B9%E3%81%AF%E3%80%81JEDEC%E3%81%8C%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%ABLOW%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81DDR3%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFRESET%E3%83%94%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81LPDDR2%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFCKE%E3%83%94%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ei.MX6%20IO%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E3%83%AD%E3%83%BC%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100423%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100423%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-objectid%3D%22203512%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FLinWang%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3ELinWang%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AERef7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CREF7%3E%3C%2FREF7%3E%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%B5%81%E3%81%AE%E6%B6%88%E8%B2%BB%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEBSP%20(%E3%83%9C%E3%83%BC%E3%83%89%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8)%20%E3%81%AF%E3%80%81DSM%20(%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89)%20%E4%B8%AD%E3%81%ABEMI%20I%2FO%E3%82%92%E3%83%87%E3%82%A3%E3%82%B9%E3%82%A8%E3%83%BC%E3%83%96%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81DSM%E4%B8%AD%E3%81%ABDRAM%E3%81%8C%E9%81%A9%E5%88%87%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%A2%20LPDDR2%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%20SDCKE%5B1%3A0%5D%20%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%20JEDEC%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%BE%E3%81%A7%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E9%81%8B%E8%BB%A2%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%A2%20DDR3%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%20JEDEC%20%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%20SDCKE%5B1%3A0%5D%20%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81DDR3%20SDCKE%E3%82%92%E3%83%AD%E3%83%BC%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%8D(%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%99%82%E3%81%AA%E3%81%A9)%E3%80%81%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%80%81i.MX6%E3%81%AFSDCKE%E3%81%AB%E3%83%AD%E3%83%BC%E4%BF%A1%E5%8F%B7%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81DDR3%E3%81%AB%E3%81%AF%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%8A%B5%E6%8A%97%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESatoshi%20Shimoda%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Pankaj%20Rana%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81Excel%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Ei.MX6SL%20HDG%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FLinWang%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%B3%E3%83%AF%E3%83%B3%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESoloLite%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E7%94%A8%E3%81%AE%E5%90%8C%E6%A7%98%E3%81%AEHW%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%82%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E--Pankaj%20Rana%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%80%81%3C%2FP%3E%3CP%3ECS%2FODT%2FCKE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%AE%E9%AB%98%E9%80%9F%E5%8B%95%E4%BD%9C%E3%81%AB%E9%96%A2%E4%B8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E3%82%BF%E3%82%A4%E3%83%88%E3%81%AB%E8%80%83%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E3%E7%95%AA%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%82%E3%81%A3%E3%81%A8%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%20Clock-200%20%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%80%81%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%20Clock%20%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%20(%E5%90%84%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E3%81%AF%20min%20max%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%3CSTRONG%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CEM%20style%3D%22font-weight%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%3C%2FEM%3E%3C%2FSTRONG%3E%E3%80%8D%E3%81%AF%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%90%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EHi%20Brett%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E2%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E9%96%93%E3%81%AB%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%5BWL%5D%20%E3%81%84%E3%82%84%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%84%E3%82%88%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%AEto%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E4%BA%92%E3%81%84%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%5BWL%5D%20%E3%83%9C%E3%83%BC%E3%83%89%E3%83%BB%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E1%E3%81%A4%E3%81%AF%E6%9C%80%E5%A4%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%BF%91%E3%81%8F%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E6%9C%80%E5%B0%8F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%BF%91%E3%81%8F%E3%81%AB%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%5BWL%5D%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%2B%2F-%205mil%E3%81%AE%E3%81%BF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%82%82%E3%81%9F%E3%82%89%E3%81%95%E3%81%AA%E3%81%84%E3%81%A8%E5%A4%A7%E3%81%8D%E3%81%AA%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20LinWang%2C%3C%2FP%3E%3CP%3E%20%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%3C%2FP%3E%3CP%3EHDG%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3A%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E4%BF%A1%E5%8F%B7(RAS%20%2F%20CAS%20%2F%20WE)%E3%82%92%E3%80%8C%3CSTRONG%3E%3CEM%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%3C%2FEM%3E%3C%2FSTRONG%3E%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EHW%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AEMX6%20DRAM%E3%83%90%E3%82%B9%E9%95%B7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E4%BF%A1%E5%8F%B7(RAS%2FCAS%2FWE)%E3%81%A8%E3%80%8C%3CSTRONG%3E%3CEM%3E%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%3C%2FEM%3E%3C%2FSTRONG%3E%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%81%AE%E6%AF%94%E8%BC%83%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELinWang%2C%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%AE%E6%96%87%E8%A8%80%E3%81%8C%E6%98%8E%E7%A2%BA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHDG%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81RAS%E3%80%81CAS%E3%80%81SDBA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3SDWE%E3%81%8C%E4%B8%80%E7%B7%92%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%BD%BC%E3%82%89%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%9C%80%E5%B0%8F%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AF%E3%81%BE%E3%81%9F%E3%80%81%E4%BA%92%E3%81%84%E3%81%AB%2B%2F-%2025%E3%83%9F%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AE%E5%88%97%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3ECS%E3%80%81SDCKE%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20SDODT%20%E3%81%AF%E3%80%81%E6%9C%80%E5%B0%8F%E6%9C%80%E5%A4%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E4%BA%92%E3%81%84%E3%81%AB%20%2B%2F-%2050%20%E3%83%9F%E3%83%AB%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E9%96%93%E3%81%AB%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%AEto%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E4%BA%92%E3%81%84%E3%81%AB%E5%AE%8C%E5%85%A8%E3%81%AB%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E1%E3%81%A4%E3%81%AF%E6%9C%80%E5%A4%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%BF%91%E3%81%8F%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E6%9C%80%E5%B0%8F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%BF%91%E3%81%8F%E3%81%AB%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBrett%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%8B%E3%82%89%E3%81%AE%E4%B8%8A%E8%A8%98%E3%81%AE%E8%BF%94%E4%BF%A1%E3%80%81Pic1%20%2F%202%20%2F%203%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-username-link%22%20data-avatarid%3D%221002%22%20data-externalid%3D%22%22%20data-presence%3D%22null%22%20data-userid%3D%22228656%22%20data-username%3D%22chenjasper%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fchenjasper%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%233778c7%3B%22%3Echen%20jasper%3C%2FSPAN%3E%3C%2FA%3E%26nbsp%3B%26nbsp%3B%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22font-color-meta-light%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93819%3Fet%3Dwatches.email.document_comment%23comment-14248%22%20target%3D%22_blank%22%3E2014%2F10%2F14%20%E4%B8%8B%E5%8D%88%209%3A11%3C%2FA%3E%26nbsp%3B%20(%3CA%20_jive_internal%3D%22true%22%20class%3D%22font-color-meta-light%20localScroll%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93819%3Fet%3Dwatches.email.document_comment%23comment-14236%22%20title%3D%22%E7%A7%BB%E8%87%B3%E8%A8%8A%E6%81%AF%22%20target%3D%22_blank%22%3E%E5%9B%9E%E6%87%89%20LinWang%3C%2FA%3E)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E5%86%99%E7%9C%9F%E3%82%92%E6%92%AE%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20LinWang%2C%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%26amp%3B%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%81%A0%E3%81%91%E3%81%AB%E9%9B%86%E4%B8%AD%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EHDG%20%E6%8E%A8%E5%A5%A8%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E4%BF%A1%E5%8F%B7%E3%81%AF%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%E3%82%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%82%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AA%E3%81%9CHDG%E3%81%8C%E3%80%8C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20RAS%2FCAS%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%A8%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%82%E3%82%8B%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%86%E3%81%AE%E3%81%8B%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%AFHDG%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%95%E3%82%8C%E3%80%81%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20LinWang%2C%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81HDG%E3%81%AFRAS%2FCAS%2FWE%E3%82%92%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7(CKE%2FCS%2FODT)%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E4%B8%80%E5%BA%A6%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EHi%20Jasper%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E7%A2%BA%E8%AA%8D%E5%BE%8C%E3%80%81%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AERAS%2FCAS%2FWE%E3%81%A8CKE%2FCS%2FODT%E3%81%AF%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%95%E3%82%8C%E3%80%81%E4%BB%96%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20LinWang%2C%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%95%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9CRAS%2FCAS%2FWE%E3%81%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AECKE%2FCS%2FODT%E3%81%A8%E3%82%82%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jasper%2C%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%A8%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%95%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%E3%82%A8%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%A7%E6%95%B4%E5%88%97%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFLinWang%3A%3C%2FP%3E%3CP%3E%20%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81RAS%2FCAS%2FWE%E3%81%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81Intel%E3%81%8A%E3%82%88%E3%81%B3Freescale%20HDG%E3%81%AECS%5B0%3A1%5D%2FODT%5B0%3A1%5D%2FCKE%5B0%3A1%5D%E3%82%92%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%AA%E3%81%9CRAS%2FCAS%2FWE%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A2%A7%E7%8E%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EHi%20Jasper%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3ECS1%2FODT1%2FCKE1%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%201%20%E3%81%A4%E3%81%AE%20CS%20%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%BB%E3%83%AB%E3%83%95%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E5%88%A5%E3%81%AE%20CS%20%E9%96%A2%E9%80%A3%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E2%E3%81%A4%E3%81%AECS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%BD%8F%E6%89%80%E3%81%A8BA%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E4%B8%8A%E9%83%A8%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20360px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46757i5B31EBAFD3AB58D5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFLinWang%3A%3C%2FP%3E%3CP%3E%E3%80%8Ci.MX6Dual%2F6Quad%20%E3%81%8A%E3%82%88%E3%81%B3%20i.MX%206Solo%2F6DualLite%20Applications%20Precessors%2C%20Rev.%201%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AC%E3%82%A4%E3%83%89%203-8%20%E8%A1%A83-3%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%90%E3%82%A4%E3%83%88%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%94%E3%81%A8%E3%81%AEDDR3%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AF%E3%80%81Pic1%2F2%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F1%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap5.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap5.jpg%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46761iACD0D480DEB8FBE6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snap5.jpg%22%20alt%3D%22Snap5.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESnap5.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F2%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap4.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap4.jpg%22%20style%3D%22width%3A%20850px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46760i020B163EBB304FEB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snap4.jpg%22%20alt%3D%22Snap4.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESnap4.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F3.i.Mx6DQSDL%20Rev2.7%20%E3%81%AE%20HW%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%82%88%E3%82%8AMX6%20DRAM%20%E3%83%90%E3%82%B9%E9%95%B7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap6.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snap6.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46759i433F3233481F3811%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snap6.jpg%22%20alt%3D%22Snap6.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESnap6.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A2%A7%E7%8E%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jasper%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%86%99%E7%9C%9F%E3%82%92%E6%92%AE%E3%81%A3%E3%81%A6%E3%80%81%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A8HDG%E3%81%AE%E9%96%93%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFLinWang%3A%3C%2FP%3E%3CP%3E%20%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%85%8E%E9%87%8D%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%8CHDG%E3%81%A8HW%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%80%81%E3%81%A0%E3%81%8B%E3%82%89%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BD%95%E3%81%8B%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%A7%E3%81%99%E3%81%8B%3FHDG%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%3CP%3E%E7%A2%A7%E7%8E%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jasper%2C%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A8HDG%E3%82%92%E6%B3%A8%E6%84%8F%E6%B7%B1%E3%81%8F%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E8%A1%A8%E3%81%AE%E5%88%A5%E3%81%AE%E8%A1%8C%E3%81%ABRAS%2FCAS%2FWE%E3%82%92%E3%83%AA%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E9%95%B7%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%88%B6%E5%BE%A1%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AEDRAM%E3%83%90%E3%82%B9%E9%95%B7%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8Ci.Mx6DQSDL%20Rev2.7%20HW%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%BB%E3%83%AA%E3%82%B9%E3%83%88%E3%80%8D%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E3%81%AFCKE%2FCS%2FODT%E3%81%AE%E3%81%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%80%81RAS%2FCAS%2FWE%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%82%8F%E3%81%8B%E3%82%8A%E3%80%81Intel%E3%82%84%E3%80%8CIMX6DQ6SDLHDG_Hardware%E9%96%8B%E7%99%BA%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8D%E3%81%AB%E3%82%82%E5%88%B6%E5%BE%A1%E4%BF%A1%E5%8F%B7%E3%81%8CCS%2FCKE%2FODT%E3%81%97%E3%81%8B%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E3%80%8Ci.Mx6DQSDL%20Rev2.7%E3%81%AEHW%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%AA%E3%82%B9%E3%83%88%E3%80%8D%E3%81%ABRAS%2FCAS%2FWE%E3%82%92%E5%90%AB%E3%82%81%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E9%95%B7%26lt%3B%3D25mil%E3%82%92%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%82%B9%E3%83%91%E3%83%BC%E3%83%BB%E3%83%81%E3%82%A7%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FLinWang%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%B3%E3%83%AF%E3%83%B3%3C%2FA%3E%26nbsp%3B%26nbsp%3B%20%E7%A7%81%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%96%B0%E3%81%97%E3%81%84Clear%E3%80%81Not%20Sure%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABYes%E3%80%81No%E3%80%81Not%20Sure%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%A5%BD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8C%E3%81%84%E3%81%84%E3%81%88%E3%80%8D%E3%81%AB%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E9%A1%A7%E5%AE%A2%E3%81%AF%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%9B%E3%81%96%E3%82%8B%E3%82%92%E5%BE%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A0%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E5%85%83%E3%81%AB%E6%88%BB%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AC%E3%83%83%E3%83%88%E3%83%BB%E3%83%95%E3%82%A7%E3%82%A4%E3%82%AC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E8%A6%81%E7%82%B9%E3%82%92%E3%81%A4%E3%81%8B%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%8E%B3%E6%A0%BC%E3%81%AA%E7%AD%89%E9%95%B7%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E8%A7%A3%E6%9E%90%E3%81%A8%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%81%A8%E3%80%81%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E5%A0%85%E7%89%A2%E3%81%A7%E3%80%81%E5%90%8C%E3%81%98PCB%E8%A8%AD%E8%A8%88%E3%81%A7PBGA%E3%81%A8FCBGA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8CL0%E3%82%92%E6%B0%97%E3%81%AB%E3%81%9B%E3%81%9A%E3%80%81%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%A8%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%A0%E3%81%91%E3%82%92%E6%B0%97%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E4%BF%A1%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDRAM%E3%81%AE%E9%95%B7%E3%81%95%E3%82%BF%E3%83%96%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9C%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEL0%E3%82%920%E3%81%AB%E4%BF%9D%E3%81%A4%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFPBGA%E3%81%A8FCBGA%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E5%86%85%E9%83%A8%E9%85%8D%E7%B7%9A%E9%95%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AEinyo%E3%82%92%E8%80%83%E6%85%AE%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%A6%E3%80%81%E5%90%84%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%BF%E3%83%96%E3%82%92%E6%8C%81%E3%81%A1%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%B1%E5%AE%B9%E7%AF%84%E5%9B%B2%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%83%95%E3%82%A3%E3%83%AA%E3%83%83%E3%83%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81i.MX6SDL%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%8CAB%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%E9%80%9A%E5%B8%B8%E3%80%81i.MX6SDL%E3%81%AFi.MX6DQ%E3%81%AE%E5%90%8C%E7%AD%89%E5%93%81%E3%82%88%E3%82%8A%E3%82%821%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%BD%8E%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81i.MX6DQ%20%22C%22%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFi.MX6SDL%20%22B%22%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22mso-spacerun%3Ayes%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Arial%20%2C%20sans-serif%3B%20color%3A%20%231f497d%3B%22%3E%E7%A2%BA%E8%AA%8D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81i.MX6DQ%20AC%E3%81%A8i.MX6SDL%20AB%E3%81%AB%E3%81%93%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFWang%20Lin%E3%81%95%E3%82%93%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%9F%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%20font-size%3A%2015px%3B%22%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20-%20%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20font-family%3A%20Calibri%2C%20sans-serif%3B%20font-size%3A%2015px%3B%22%3EeMMC%2FSD%E3%83%95%E3%82%A1%E3%82%B9%E3%83%88%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81i.Mx6%E3%81%AE%E3%80%8CSDx_RESET%E3%80%8D%E3%83%94%E3%83%B3%E3%82%92%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%81%A8%E6%AD%A3%E3%81%97%E3%81%8F%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E(%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E9%A0%85%E7%9B%AE%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%BB%A5%E9%99%8D%E3%81%A7%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E6%AD%A3%E7%A2%BA%E3%81%AB%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E9%A0%85%E7%9B%AE%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%20SD%20%E3%83%90%E3%82%B9%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81SI%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%8C%E4%B8%8D%E9%81%A9%E5%88%87%E3%81%A7%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%95%B7%E3%81%84%E3%83%90%E3%82%B9%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%96%A2%E9%80%A3%E6%83%85%E5%A0%B1(0x450%5B10%5D%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%A8%E3%83%81%E3%83%83%E3%83%97%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0IMX6Q%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SD3%2F4%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%20BOOT_CFG1%5B7%3A0%5D%3D%200100%200000%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E3%82%88%E3%81%B3%20BOOT_CFG2%5B7%3A0%5D%3D%200011%200000%E3%80%82SD3%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%20-%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88(POR_B%3D0)%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%99%E3%81%A8%E3%80%81%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A8%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81USB%E7%B5%8C%E7%94%B1%E3%81%A7DDR%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81IMX6Q%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E9%A0%BB%E7%B9%81%E3%81%99%E3%81%8E%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ERR006282%E3%82%A8%E3%83%A9%E3%83%83%E3%82%BF%E3%81%AB%E3%81%AF%E3%81%AA%E3%82%8A%E5%BE%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%8CMMC%20%2F%20SD%E3%83%96%E3%83%BC%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DLL%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABBOOT_CFG2%5B2%5D%E3%82%92%E9%AB%98%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E6%AD%A3%E8%AA%A4%E8%A1%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E8%A9%B3%E7%B4%B0%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%AE%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%89%E3%80%81%3C%2FP%3E%3CP%3ECKE0%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A6%81%E4%BB%B6%E3%81%AF%E5%8E%B3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%AF%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%83%AA%E3%83%B3!%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%82%E3%82%8B%20CKE0%20%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%86%85%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%82%88%E3%82%8A%E3%82%82%E7%9F%AD%E3%81%8F%E3%80%81%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Rowlan%2C%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B0%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EExcel%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEL0%E3%81%AF%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%20%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%5BMX6%20DRAM%20Bus%20Length%20Check%5D%20%E3%82%BF%E3%83%96%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%90%E3%82%B9%E3%81%AB%20%5BMX6%20DRAM%20Bus%20Length%20Check%5D%20%E3%82%BF%E3%83%96%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%90%E3%82%B9DRAM_D48%20%E3%81%8B%E3%82%89%20DRAM_D63%20%E3%81%BE%E3%81%A7%E3%81%AE%20L0%20%E5%80%A4%E3%81%8C%20300%20%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%80%A4%E3%81%A7%E5%9F%8B%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%94%E3%83%B3%E3%81%8C0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%A4%9A%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%20%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%20L0%20%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fuser_guide%2FIMX6DQ6SDLHDG.pdf%3Ffpsp%3D1%26amp%3BWT_TYPE%3DUsers%2520Guides%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dpdf%26amp%3BWT_ASSET%3DDocumentation%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EIMX6DQ6SDLHDG%3C%2FA%3E%20%E3%81%A8%E5%BD%93%E7%A4%BE%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%B5%8C%E9%A8%93%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E8%A6%81%E7%B4%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%AE%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20HW_Design_Checking_List_for_i.MX6DQP6DQ6SDL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%20Web%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%AB%E6%8E%B2%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%85%AC%E5%BC%8F%E3%81%AE%20H%2FW%20Developers%20Guide%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20-%20%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2F32bit%2Fdoc%2Fuser_guide%2FIMX6DQ6SDLHDG.pdf%3Ffpsp%3D1%26amp%3BWT_TYPE%3DUsers%2520Guides%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dpdf%26amp%3BWT_ASSET%3DDocumentation%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EIMX6DQ6SDLHDG%3C%2FA%3E%20%E3%81%AF%20%22User%20Guides%22%20%E3%82%B5%E3%83%96%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDocumentation_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDocumentation_Tab%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-21-2012 10:39 PM
更新者:
