There is a DDR Layout guide in IMX8MNHDG and there are routing recommendations but units are ps.
I need recommendation route signal length. May I get recommendation routing signal length to design layout with LPDDR4?
Solved! Go to Solution.
all of length matching delay is posted in the hardware guide, the suggestion from HW team is "Our primary recommendation is to follow our reference design as much as possible and to minimize the trace length."
you also can refer to the document as below:
“https://www.nxp.com.cn/docs/en/application-note/AN12298.pdf”
